Is it possible to concatenate a number of treks in Traveller?
Submitted: Saturday, Apr 13, 2024 at 15:23
ThreadID: 147513 Views:1272 Replies:4 FollowUps:7
I have created a number of treks for an upcoming trip from Perth to Darwin. Each has quite a bit of detail with points of interest to stop etc.
Can I join these all together in one to get a single overall trek?
I ultimately want to create a summary plan for our trip to import Google Maps/Google Earth. At the moment I am limited by the number of layers (each trek is a layer) that can be loaded into Google.
Reply By: TrevorDavid - Sunday, Apr 14, 2024 at 06:21
Dave
Yes you can.
Create a folder. Place all of your Treks and in fact any data you wish into the folder. Highlight / turn on the folders tab in map layers, highlight your newly created folder & all will show on your map.
Have a look at the quick start guide & using maps and data in the help guide. Really easy to do.
TrevorDavid
dontyajustluvit
AnswerID: 645664
Follow Up By: Member - davewebby - Sunday, Apr 14, 2024 at 12:28
Thanks, Yes, I have no problem displaying all the treks in the traveller map (my treks etc are already orgnanised into a folder). I want to be able to combine these all into a single trek so I can export as a .GPX file and load into Google Maps (specifically the Trip Planner in Google Maps).
FollowupID: 925998
Follow Up By: TrevorDavid - Sunday, Apr 14, 2024 at 21:05
Dave
I sent you a member message.
TrevorDavid
dontyajustluvit
FollowupID: 925999
Follow Up By: Bonz (Vic) - Monday, Apr 15, 2024 at 17:17
Hey TDB, drop the solution in here too mate, it will interest quite a few members methinks
FollowupID: 926004
Follow Up By: TrevorDavid - Monday, Apr 15, 2024 at 20:05
G’Day Bonz it’s been too long mate.
Basically it’s the same as creating any other Trek. Rather than waypoints/ places, you use an already created Trek.
Treks, Personal Treks, select your starting Trek & swipe left, hit the go to tab, then follow the normal Trek creation process. Then second Trek , third Trek etc. When all the Treks have been added hit save, name it etc as per normal and it will save in your personal Treks .
TrevorDavid
dontyajustluvit
FollowupID: 926005
Follow Up By: Bonz (Vic) - Monday, Apr 15, 2024 at 20:49
Definitely Trev. Definitely
FollowupID: 926006
Reply By: Member - peter g28 - Sunday, Apr 14, 2024 at 20:33
I don't think the ExploreOz Traveller App has the capability to combine all your treks into a single trek and then export them as a GPX file to another application.
AnswerID: 645668
Reply By: Member - Warren H - Monday, Apr 15, 2024 at 09:58
You can combine treks by opening treks in order and adding to the end. This can then be saved as the combined trek.
NT Pajero
2007 Goldstream Crown
AnswerID: 645669
Follow Up By: Member - davewebby - Monday, Apr 15, 2024 at 10:36
Thanks Warren. I eventually figured this out (by accident!). However, when I did this I got a random point out west in the middle of the ocean (which I assume is some sort of map origin point). This in turn screwed up the export of the GPX file (I tried to delete the point - it was marked as an airline symbol - but it just ended up being inserted somewhere else).
I gave up and spent a couple of hours repicking the entire trip into a single trek!
FollowupID: 926001
Follow Up By: TrevorDavid - Monday, Apr 15, 2024 at 14:33
Just to add to Warrens post,
After combining into a single Trek, go to Traveller control panel in the website, my personal Treks, map, then download Trek in the format required. .GPX, .CSV, Oziexplorer or Hema Navigator
TrevorDavid
dontyajustluvit
FollowupID: 926002
Reply By: Sidney N - Monday, Apr 15, 2024 at 11:56
This post has been read by the moderation team and has been moderated due to a breach of The Spamming Rule .
Forum Moderation Team
AnswerID: 645670
