Monday, Jul 08, 2024 at 08:37
Hi Sean,
Despite the comments from those who obviously do not have a
well prepared Touring Rig, you can cross the
Simpson Desert in pretty much any
well prepared stock high ground clearance 4WD. My son crossed in a stock standard 4WD Hilux, no lift, no Bullbar, no winch and no Maxtrax. Whilst we carried these, he did not and did not need them. However, I would not recommend crossing without at least a set of 4 Maxtrax and a shovel, if you are travelling solo.
The secret is high ground clearance, correct tyre pressures, not being too heavy, and being able to carry enough fuel and supplies to last 4 to 5 days. Whilst it should not take you 5 days to cross, you need enough supplies, particularly water, to last until assistance arrives if you get stuck or
breakdown. You should not rely on others for emergency food or water. If you know what your fuel consumption is like normally, you will need to make allowances for the extra you will use being in sand.
You will need a South Australian Desert Parks Pass, (obtainable online), a
UHF Radio tuned to Channel 10, and an approved Sand Flag at the appropriate height and position on your vehicle, all are mandatory. A 5 Watt handheld radio will suffice, as long as you have a means of charging it along the way. A Satellite Phone whilst not mandatory would be good to have as
well, you can hire one for the time it takes for the crossing. A PLB or EPIRB would also be a good addition in case the worst was to happen.
I would also recommend you contact The
Birdsville Hotel and enquire about their Recovery Insurance. $499:00 I think. If you do not need it, you do not get your money back, but it is better than $10,000:00 minimum if you did need recovering and you did not have it, particularly if you are travelling solo.
I would recommend that you
check the track conditions and the weather just before making the crossing. The track is likely to be cut up at that time of year, as both the Finke Desert Races, and the
Birdsville Bash which were held in the last couple of weeks will have undoubtedly left the track in pretty bad shape.
Good luck, it is a great trip. Plan a stop at
Dalhousie Springs for a dip. I have crossed three times, twice from West to East, and once from East to West, all on the QAA & French Lines.
646153
Follow Up By: Allan B (Sunshine Coast) - Monday, Jul 08, 2024 at 15:50
Maxtrax ??? …….Nah Macca. If a Jimny gets bogged you just pick it up and move it. lol
926637
Follow Up By: AlbyNSW - Tuesday, Jul 09, 2024 at 08:05
Alan years ago I did some work up in the PNG highlands and the little Suzuki’s were the way to go as the strong locals just picked them up carried them through the bogholes if they got stuck
926645
Follow Up By: Allan B (Sunshine Coast) - Tuesday, Jul 09, 2024 at 08:44
I can
well believe that Alby. I have great respect for those little Suzi's.
My first car (in 1950) was a little Baby Austin Seven and I could lift one end of it on my own to drag it into a tight
parking space. In later years, my ride-on mower had twice the horsepower!
Incidentally, an Austin Seven was the first car to drive unaccompanied up the peninsular to the tip of
Cape York….
(Link)
Edit: Here is a
Link to a re-creation of that journey in 2015 and a
pic of the replica Austin at
Laura.
Austin Seven at Laura.
926649
