Maps not showing speed limit
Submitted: Friday, Aug 23, 2024 at 16:49
ThreadID: 148279 Views:1595 Replies:5 FollowUps:2
I have version 9 and it does show the speeds for my location as I have it turned on in the settings
Reply By: TrevorDavid - Saturday, Aug 24, 2024 at 05:29
Well good on you for turning it on. LOL
TrevorDavid
dontyajustluvit
AnswerID: 646386
Reply By: Mike_Suzy - Saturday, Aug 24, 2024 at 08:33
Sorry I meant that it doesn’t show road speed even though I have that tunnel on in settings
AnswerID: 646388
Follow Up By: Member - Bam - Saturday, Aug 24, 2024 at 10:43
I believe that it only shows up when you are moving perhaps that’s why it’s not currently showing on your display.
FollowupID: 926956
Follow Up By: TrevorDavid - Saturday, Aug 24, 2024 at 20:41
M_Z
Only available on EOTopo 2023 & 2024 map sets
Not on satellite or streets & paths.
As Bam has said need to be on the move.
There is the help desk as Allan B has suggested BUT you can ask on the forum as well
TrevorDavid
dontyajustluvit
FollowupID: 926957
Reply By: Allan B (Sunshine Coast) - Saturday, Aug 24, 2024 at 13:06
Mike, or maybe Suzy or whoever, you are posting on the Forum page. Perhaps it would be more appropriate to raise your issue on the Traveller Help Desk Support page here.
AnswerID: 646389
Reply By: ExplorOz - David & Michelle - Tuesday, Aug 27, 2024 at 08:39
Mike_Suzy,
Hi there, not all roads have speed attributes in the data and thus will not show a speed limit. Most residential roads that are unsigned 50 zones fit this description however most signed roads do have the data. Hope this helps..
David
Currently Mapping in the Field Across Australia Fulltime in 2024 - 2025
AnswerID: 646405
Reply By: william m9 - Wednesday, Sep 18, 2024 at 08:07
hi analysis these steps
To fix maps not showing speed limits:
1. **Enable Speed Limit Display:** Check app settings.
2. **Update the App:** Ensure you have the latest version.
3. **Check Location Services:** Confirm the app has location permissions.
4. **Restart the App/Device:** Sometimes, a simple restart helps.
5. **Reinstall the App:** Uninstall and reinstall if needed.
If the issue persists, check the app's support page for more help.
AnswerID: 646522
