GPS module for iPad
Submitted: Monday, Aug 26, 2024 at 11:26
ThreadID: 148322 Views:1113 Replies:5 FollowUps:1
Hi guys I’m after a bit of information on GPS modules if possible. I’m wanting to use an iPad for navigation but unfortunately the one I have doesn’t have a sim so no built in GPS. I’d appreciate some feedback on the GPS units that you are using as the information on line is a bit overwhelming. Cheers in advance Blackie
Reply By: Stephen L (Clare) SA - Monday, Aug 26, 2024 at 11:56
I have a Bad Elf, brilliant and used by the aviation industry for reliability and accuracy
Smile like a Crocodile
AnswerID: 646399
Reply By: Glenn M8 - Monday, Aug 26, 2024 at 17:55
Hi Blackie
I have been using a Garmin unit with an iPad for years now and find it an excellent piece of equipment. I am sure others will have varying views on it but for me it works well. The unit I use is a Garmin GLO2 and you can pick one up for about $165 at Johnny Appleseed GPS store.
Glenmac
AnswerID: 646400
Reply By: ExplorOz - David & Michelle - Monday, Aug 26, 2024 at 20:28
We also have the Garmin GLO2 and have used it for years, it has reliable operation. We also have the extra non slip case and use it for app development and testing.
David
Currently Mapping in the Field Across Australia Fulltime in 2024 - 2025
AnswerID: 646403
Follow Up By: Member - Bam - Tuesday, Aug 27, 2024 at 09:24
I too have been using exactly the same setup for the last few years without any issues whatsoever.
The non-slip case is a worthy addition as it simply & easily holds the GPS in place on the dash even when travelling over rough & bumpy terrain.
FollowupID: 926961
Reply By: Member - McLaren3030 - Tuesday, Aug 27, 2024 at 06:54
Hi Blackie,
Like Stephen, I also use a Bad Elf GPS in my iPad, works well.
AnswerID: 646404
Reply By: Member - Blackie - Wednesday, Aug 28, 2024 at 14:47
Thanks for the information guys. I went with the Garmin GLO 2
Kind regards Blackie
AnswerID: 646424
