Wheel nuts
Submitted: Sunday, Mar 12, 2023 at 14:54
ThreadID: 145414 Views:1932 Replies:6 FollowUps:1
Can anyone advise if the wheel nuts from a standard steel rim be suitable for a alloy rim to suit the 200 series
Reply By: Member - LeighW - Sunday, Mar 12, 2023 at 15:18
No, you will need alloy wheel lug nuts
AnswerID: 643060
Reply By: Bob Y. - Qld - Sunday, Mar 12, 2023 at 16:13
These are what you need, Rude.
AnswerID: 643061
Reply By: Member - Duncan2H - Sunday, Mar 12, 2023 at 19:47
The consequences of getting this wrong are significant.. it would be worth being very certain of the requirements of your rims with regards to the nuts - especially if they are aftermarket rims.
AnswerID: 643062
Reply By: Member - Boobook - Monday, Mar 13, 2023 at 06:13
It depends on the alloys you use. For OE the type shown above are correct. For others the steel wheel ones may be correct.
You should consult the manufacturer.
AnswerID: 643063
Reply By: Michael ( Moss Vale NSW) - Monday, Mar 13, 2023 at 06:50
Some alloy wheels have countersunk holes and use the nuts Bob has shown above and some alloy wheels have a steel insert pressed into them with a tapered seat and use the same tapered seat nuts as steel wheels. So best do your own research so you you get the correct ones.
Patrol 4.2TDi 2003
Somewhere you want to explore ? There is no time like the present.
AnswerID: 643065
Reply By: Member - DOZER - Tuesday, Mar 14, 2023 at 12:48
Not thesame, mags run mag nuts, steelies run tapered seat nuts. If your after mags, check mine which come with nuts.
b4 you bag me out, walk a mile in my shoes, then your a mile away and have my shoes :)
Classifieds: Landcruiser 200 roadsafe v3 front recovery points, 100 or 200 series landcruiser 18x8 factory rims with tyres GC
AnswerID: 643075
Follow Up By: ExplorOz - David & Michelle - Wednesday, Mar 22, 2023 at 13:39
Wish your Classifieds rims where the same as our 200 I need to get a few more or swap them all out.
David
Always working not enough travelling!
FollowupID: 922777
