Camping appliances
Submitted: Tuesday, Aug 27, 2024 at 19:41
ThreadID: 148343 Views:2502 Replies:20 FollowUps:22
We are going to be doing a 6 month trip around Oz next year in our caravan. We have a 1000watt inverter, 3 x 100 watt solor panels on the roof and 3 x 120 Ah AGM batteries. So I know I'm not going to be able to run any appliances like a kettle with that. So what do you guys do on the road with regards to your cooking? We have gas bottles that will run the oven and also a hot plate and gas stoves. I really wish I could run a kettle so I'm not having to use gas to simply boil water for a cup of tea!! I've looked online and apparently you can get kettles that can be powered in the car, that have the cigarette lighter attachment? Has anyone used these? Any advice would be so appreciated as we're travelling with two kids so trying to get things sorted as much as we can! Thankyou
Reply By: Member - rocco2010 - Tuesday, Aug 27, 2024 at 19:54
Need quick hot water for morning tea? Buy a couple of good thermoses (is that the plural of thermos?)
Fill em up at breakfast and you have instant hot water through the day for a cup of tea without the hassle of boiling a kettle.
I used to pull out the little gas stove at smoko but switched to a thermos a few years ago. Saves time and hassle.
AnswerID: 646409
Follow Up By: Batt's - Wednesday, Aug 28, 2024 at 05:48
Totally agree with the Thermos fastest way to make a cuppa during the day.
As for cooking when my wife makes baked dinners spag bowl etc she makes a few extra and freezers them at home we always have something there I take them to work as well. They are good for those days you don't feel like cooking tea if you know your going to arrive late or whatever we just put 2 in the fridge for that and keep about 4 or 6 in the freezer depending on room. Put 2 of them in the Travel Buddy Marine for a couple of hours before arriving at your destination for a quick easy nice hot meal.
FollowupID: 926965
Follow Up By: RMD - Wednesday, Aug 28, 2024 at 08:23
Rocco
The problem with a thermos is: You still have to BOIL the water in the FIRST PLACE. Thermos is only a, management of situation tool, not a hot water creation tool.
FollowupID: 926967
Follow Up By: Member - rocco2010 - Wednesday, Aug 28, 2024 at 08:41
RMD
You have to boil water to fill a thermos?
Who knew?
The OP asked about having a hot water for a quick cup of tea during the day.
I find it convenient to boil the water in the morning while having. breakfast and packing up.
It’s then immediately available at smoko.
Works for me.
FollowupID: 926968
Follow Up By: Nomadic Navara - Wednesday, Aug 28, 2024 at 10:08
Quote RMD - "You still have to BOIL the water in the FIRST PLACE."
Of course you do! The point is, what is the cheapest and most convenient way of doing it. Most travellers heat/boil water at breakfast time. Boiling the kettle the second time can be done whilst you are doing other things (perhaps the washing up.) If you have a vacuum flask at hand, it saves time later on getting out special equipment and waiting whilst it boils. If you boil your water at breakfast time, the fuel on hand is cheaper than the fuel in smaller canisters.
My cook has been doing this for around 30 years. She fills the flask every morning. If we are not on the road or picnicking that day the water does not get wasted, it is used for washing up that night.
FollowupID: 926971
Reply By: Allan B (Sunshine Coast) - Tuesday, Aug 27, 2024 at 20:17
Kathy, those 12v kettles you refer to are no more than a laugh. They take forever to boil a cup of water and consume a great deal of battery capacity in doing it.
The simple truth is that whilst electricity is appropriate to drive motors and LED lights, it is very inefficient at heating tasks, be that by resistance elements, induction cooktops or microwave ovens. Sure, some use these appliances from batteries but they consume huge amount of electricity that then has to be replaced by powerful charging sources. Your 300W of solar is barely enough to run a fridge and LED lights.
You are equipped with a gas stove so what is it about that causing you dismay for heating water?
Classifieds: FREE BOOKS
AnswerID: 646410
Reply By: IvanTheTerrible - Tuesday, Aug 27, 2024 at 21:22
Use gas for anything you can. The only thing you may want the invertor for is a microwave. Rubbing your hands together in water will heat it quicker than a 12v kettle
AnswerID: 646411
Follow Up By: RMD - Tuesday, Aug 27, 2024 at 21:50
The 1000w inverter has NO CHANCE of running a microwave. Even a small 700 COOKING WATTS Microwave demands 1300WATTS of BATTERY while running.
FollowupID: 926963
Follow Up By: IvanTheTerrible - Wednesday, Aug 28, 2024 at 19:42
The ones I've seen in caravans have only 400w and we have had customers running them on 1000w invertors on a single battery. People dont run them for very long usually only minutes
FollowupID: 926975
Reply By: RMD - Tuesday, Aug 27, 2024 at 21:47
Hello Kathy
I have a very old 12v kettle, has to be 60 years old as my Dad used it when travelling with his job. It had alligator clips direct to battery and heavy thick resistance for the heater. NO CIGGY PUG WOULD EVER run it! Even that took a long time and used plenty of battery. For the time and Battery used, it is pretty useless. 10Amp ciggy plug won't run 40amp heater coil. I use a bush kettle with the tapered inner sleeve and hole at the top. They capture heat well from any gas burner ring or even small sticks/twiggs burnt inside it's base, used where applicable. On one of the butane burners it heats quickly. 4 mins for a cuppa or 2. Forget 12v for water heating/boiling.
360 AH of AGM is a lot of weight to cart around if never using all of it or anywhere near half of it. Depending on what you NEED to run/operate, it might be better to have a lightweight butane portable burner and ditch an AGM, or two. Weight saving?
Depending on the CLAIMS made for the panels, 300watts of solar is "only/maybe" near 250watts in ideal conditions, if lucky. I would be surprised if it equated to 150W average, so you may have less capacity to charge batteries anyway. Has anyone actually tested the system so you know what it can provide for you?
I don't want to sound negative, but many items sold for 12 charging and storage are not as capable as claimed by the sellers. They sound good on paper. A bit of analysis of what you want to achieve and what the gear can actually do, will provide enough awareness and time to rectify any deficiencies. It will save heartache at the most inoportune times.
AnswerID: 646413
Reply By: Hugh J2 - Tuesday, Aug 27, 2024 at 23:04
Go to anaconda and get urself a "jetboil" boils half a ltre of water in 2minutes . Its gas powered and abt the size of a large travel mug.
AnswerID: 646414
Follow Up By: Nomadic Navara - Tuesday, Aug 27, 2024 at 23:14
They are expensive stuff - You searched for "jetboil" . Their gas is $16 for a 230 g or $22 for a 430 g canister.
FollowupID: 926964
Follow Up By: Briste - Wednesday, Aug 28, 2024 at 08:51
I have a Jetboil that I make occasional use of for fast boiling water, esp for roadside coffee. Also for when I'm offgrid in less than ideal solar conditions. It works well, although I'm not sure about the economics for regular use. My tins last quite a while for occasional use, so the cost is worth the convenience
As a later post suggested, a 1000W inverter isn't of all that much use, and an upgrade to a larger one if the batteries will support it would make a lot of sense.
FollowupID: 926969
Follow Up By: Peter_n_Margaret - Wednesday, Aug 28, 2024 at 10:00
A 1,000W inverter can be very useful if you can deliver, replace and store the energy required.
Ours is a bit bigger at 1300W because that was the biggest we could afford 20 years ago.
We boil water in an electric jug constantly, bake bread, run electric blankets, even heat the HWS sometimes when there is plenty of solar. Plus all the smaller jobs. Our gas usage is about 1kg per month.
FollowupID: 926970
Follow Up By: Member - Bam - Wednesday, Aug 28, 2024 at 10:55
We use a JetBoil as a quick & convenient way to boil water for a cuppa whilst travelling.
The 430g JetBoil branded canisters with the better gas mixture for use in cold temps can be bought for about $19 if you search around.
The JetBoil uses approx. 5gms of gas to boil 500ml therefore a 430g canister can boil about 43l of water (about 172 cuppas) costing about 22 cents/500ml boil.
I’m more than happy to pay that just for the speed & convenience alone.
FollowupID: 926972
Reply By: Hugh J2 - Wednesday, Aug 28, 2024 at 00:52
Bunnings sell gasmate power cell 230g for $4.50. These are bigger than jetboil but not an issue to carry them separate, still fits and works fine. I think there is a cheaper chinese knock off on ebay.
AnswerID: 646415
Reply By: qldcamper - Wednesday, Aug 28, 2024 at 04:13
I have done reasonably well from those 12 volt kettles. Must have been paid to replace the thermal fuses in ciggy lighter sockets 3 or 4 times a year since I was an apprentice.
AnswerID: 646416
Reply By: AlbyNSW - Wednesday, Aug 28, 2024 at 05:34
Just use your gas or we prefer to use a small butane canister cooker as they are quicker
AnswerID: 646417
Reply By: 2517. - Wednesday, Aug 28, 2024 at 07:45
Realistic you need 600 watt of solar to charge 3 120 amp batteries,and good weather conditions. Why not use gas ,it cheap and does the job.
AnswerID: 646418
Reply By: Member - McLaren3030 - Wednesday, Aug 28, 2024 at 08:03
Hi Kathy W2,
Firstly, let me state that I am not an Auto. Elec. or a 12 volt specialist, just someone who has been camping for more than 55 years.
After reading the responses so far, I am sure by now you get it that 12 volt kettles are not the way to go. As a couple of responders have mentioned, any 12 volt appliance used for a heat source is going to consume quite a lot of battery capacity, and will take a long time doing it. Electric Kettles and Jugs are for when you have a good 240 volt power supply, such as in a caravan park, gas is by far a quicker and cheaper alternative for heating water or cooking when “off grid”.
As for Battery capacity, if you have a compressor fridge, the minimum battery capacity I would suggest is 200 AmpHrs of preferably LiFePo4 batteries, and a minimum of 400 watts of solar capacity. The general rule of thumb is that for every battery amp you have, you need double the watts of solar capacity. Some people argue that you can get away with less, but the vast majority will agree with the 2 for 1 ratio. So for your current 360 AmpHrs of battery capacity, you really need 720 watts of solar capacity. You can supplement your current Solar capacity by using portable folding panels or folding blanket. Remember, depending on where you are located in the country, and the time of year, there is only around 4 to 5 hours of optimal solar charging conditions. Also, as someone else has mentioned, you will be lucky to get half of the rated capacity from your solar panels, particularly if they are flat roof mounted. They also need to be in full sun to be efficient.
Your 1,000 Watt inverter is not going to run much in the way of electrical appliances other than phone, tablet and camera battery chargers, the majority of which can be run from a 12 volt power supply anyway.
What do you run from your 1,000 Watt Inverter? Given that appliances such as Electric kettles, toasters, induction cooktops etc. pull over 1,000 watts, it would seem to be a bit small. Depending on what 240 volt appliances you are running, it might be better to upgrade to a larger inverter. You need to match the inverter to the current draw of the appliances that you want to run, with a slightly higher margin to avoid tripping the inverter on overload. Your batteries also need to be able to deliver the continuous discharge amperage the appliance requires.
As a bare minimum, even if you do nothing else, increasing your current solar capacity to the 720 watts as suggested, will help your current set up cope with being off grid for a couple of nights.
AnswerID: 646419
Reply By: Member - peter g28 - Wednesday, Aug 28, 2024 at 10:44
I agree what others have said, use the gas to "heat" water for your morning cuppa...but do a bit of planning..sort of get "two for the price of one"...especially if you are free off grid camping.
So..have your cuppa in the morning when you are making breakfast..so you heat up your water for both the cuppa and for water to clean the breakfast dishes..same at night when you have finished dinner.
When you are off grid and if you have thecamp fire going..again use the fire to boil some water
Then if you are travelling for the day..heat up some extra water in the morning to put in the thermos..a good quality thermos can keep hot water for over 6 hours.
If you are camping in caravan parks..use their camp kitchen..take your dishes over and clean them plus boil the water using their electricity....your camp fee are paying for it!
AnswerID: 646421
Follow Up By: Member - rocco2010 - Wednesday, Aug 28, 2024 at 11:22
As a swag camper I love a good camp kitchen when I find myself in a caravan park!
Sometimes well worth the price.
Good idea to carry a plug for the sink! I know from experience.
FollowupID: 926974
Reply By: Member - Jim S1 - Wednesday, Aug 28, 2024 at 12:57
Hi Kathy
Use gas , quick to heat , and we use two good quality thermoses.
Wash up with whatever is left over.
Has worked well for many a year.
Jim
"Sometimes I sits and thinks, and sometimes I just sits." A fisherman.
"No road is long with good company." Traditional
AnswerID: 646422
Reply By: Member - silkwood - Wednesday, Aug 28, 2024 at 14:39
Kathy, your battery capacity is reasonable (Lithium would be better) but, as mentioned, your solar is not really going to keep up with heavy use, particularly if it is on a van roof (not ideal direction-though workable, but you often want the van in the shade!).
If you want to use an inverter (and, disagreeing with many here I find them useful) you may want to up your solar (preferably with portable that can be in the sun more directly) and your inverter to a 2000w. Your batteries should cope so long as you aren't overusing the inverter. Again, you'd be better off with lithium .
Mark
AnswerID: 646423
Reply By: Member -Pinko (NSW) - Wednesday, Aug 28, 2024 at 16:16
Over many years we have used a Coleman dual fuel sportster single burner for roadside hot water. Its coming to the end of its long life and sadly no longer available so probably replace it with a jetboil zip.
AnswerID: 646425
Follow Up By: Richard M29 - Wednesday, Aug 28, 2024 at 19:54
As a 54 year camper(65yo), I agree with every comment here - listen to them.
FollowupID: 926976
Reply By: Member - David M (SA) - Wednesday, Aug 28, 2024 at 20:54
Spent many years trying to find a simply way to boil water for a cup of tea. Gave up and decided to just drink
coffee instead.
Dave.
AnswerID: 646431
Follow Up By: RMD - Thursday, Aug 29, 2024 at 08:32
Cold coffee? Sounds great!
FollowupID: 926977
Follow Up By: Nomadic Navara - Thursday, Aug 29, 2024 at 10:04
And how do you make coffee without having to boil a jug/kettle first?
FollowupID: 926978
Follow Up By: Member - Jim S1 - Thursday, Aug 29, 2024 at 10:44
Come on people, good coffee should be made with hot , not boiling water.
Of course, using “instant” coffee means all bets are off !!
Jim
FollowupID: 926979
Follow Up By: Batt's - Thursday, Aug 29, 2024 at 11:05
To make coffee without boiling water is easy just go to the fridge and pull out an ice coffee flvoured milk give it a shake and hey presto. Same thing for tea as well so I may have just come up with the best solution overall no extra gas used it's less time consuming and takes up a small portion of fridge space problem solved.
FollowupID: 926980
Follow Up By: Allan B (Sunshine Coast) - Thursday, Aug 29, 2024 at 13:02
C’mon guys, to get a nice hot coffee you go to a good coffee shop and order your choice. Simple.
FollowupID: 926981
Follow Up By: Nomadic Navara - Thursday, Aug 29, 2024 at 17:42
No bloody way. If I am travelling, I don't want to spend time parking the rig, walking to the shop, waiting in line to order, waiting for it to be delivered, walking back to the rig and then fighting the traffic to get back onto the main road. I am not one of those unfortunately addicted to café coffee.
When I am on the road, I like to be able to pull into a roadside rest area, pour out a warm drink, consume it and then get on with my journey. If I need a bit of a rest, I can add the time people waste finding a shop in town to my normal quick stopping time and have a real rest.
FollowupID: 926982
Follow Up By: Member - McLaren3030 - Friday, Aug 30, 2024 at 07:12
This is how I do my coffee on the road. 2,000 Watt inverter, connected to a 175 AmpHr LiFePo4 battery.
ps. The grey power lead is the 240 volt supply lead for the fridge when camped at a campground.
FollowupID: 926984
Follow Up By: Batt's - Saturday, Aug 31, 2024 at 12:51
Very flash McLaren. If I show my wife she's going to want one.
FollowupID: 927000
Follow Up By: Allan B (Sunshine Coast) - Saturday, Aug 31, 2024 at 17:50
Peter, it was a joke!!!!!
FollowupID: 927005
Reply By: ExplorOz - David & Michelle - Wednesday, Sep 04, 2024 at 20:17
We have Nespresso pod machine too and a JetBoil used for Davids “noodles” lunch every now and then. I often make a tea or miso soup using hot water from either the coffee machine or jetboil. Would not go anywhere without the Jetboil. 2000w invertor and Lithium in back of Landcruiser with 38L Waeco and 40l water tank so we dont need to use the Ultimate during midday stops. Camper has its own separate invertor, fridge, water and coffee machine too.
MM
AnswerID: 646483
Reply By: mark s57 - Monday, Sep 16, 2024 at 18:34
Camping appliances can greatly enhance your outdoor experience by adding convenience and comfort. Here are some popular options:
Portable Stove/Grill: Essential for cooking meals, look for models that are easy to set up and use. Options include compact camping stoves or small portable grills.
Cooler: A good cooler will keep your food and drinks fresh. Consider a high-quality, durable cooler with good insulation.
Camping Lantern: A reliable lantern provides essential lighting. LED lanterns are popular for their long battery life and bright illumination.
Portable Coffee Maker: If you love your coffee, a portable coffee maker or French press can be a great addition.
Camping Shower: For a refreshing wash, consider a portable camping shower that can be hung from a tree or mounted on a stand.
Inflatable Sleeping Pad: For added comfort while sleeping, an inflatable sleeping pad provides cushioning and insulation from the ground.
Portable Power Bank: To keep your devices charged, a high-capacity portable power bank or solar charger can be very handy.
Campfire Cookware: Lightweight pots, pans, and utensils designed for camping make cooking and cleaning easier.
Portable Fridge: For extended trips, a portable fridge can keep your perishables fresh and beverages cold.
AnswerID: 646517
Reply By: mark w53 - Friday, Sep 20, 2024 at 05:31
Kmart Jet Boil. I use this for hiking but would be ideal for your morning Cuppa. About $70 and replacement gas can about 20 from BCF. There is a few different brands but gas is the same. You would get Hot water in a couple of minutes for 2 cups of coffee.Kmart Camp Stove
AnswerID: 646526
Reply By: Anthony T8 - Sunday, Sep 22, 2024 at 19:08
FWIW
Daughter and family just completed 6 months trip around Oz Many offgrids up to 7 days. Upgraded to 3 lithium batteries plus 700w on van roof before leaving. Ran everything (coffee plus washing machine, showers , huge fridge freezer etc.) whenever wanted. No issues.
Just saying, as it is a big trip with lots to experience without any hassles over gear.
Happy travels.
AnswerID: 646539
Follow Up By: Member - McLaren3030 - Monday, Sep 23, 2024 at 07:45
Hi Anthony,
No offence intended, but it is one thing to say 7 days off grid without issues, but were those 7 days sitting stationary, or were they moving every day?
There is a big difference between being able to sit stationary off grid for 7 days, and being off grid for 7 days but driving every day recharging your batteries. What capacity are the LiFePo4 batteries? What size Inverter? What output in Amps is the DC/DC Charger?
We prefer off grid camping, only using caravan parks when we absolutely need to, and have sat stationary for up to a month without any real problems. Having said that, we were in southern NSW in April alongside a river. Our caravan has 2 x 100 AmpHr LiFePo4 batteries and 500 watts of fixed roof mounted solar panels, plus another 200 watt folding solar blanket, and a 2.2 KVA Generator as back up. There was a further 120 amps of AGM Auxiliary batteries (made up of a 70 AmpHr and a 50 AmpHr) in the towing vehicle powering a 60 Ltr. Engel fridge. On this particular occasion, the generator was used only once, after 3 days of overcast and rain.
Since then, I have replaced the 120 amps of AGM, with a single 175 AmpHr LiFePo4 Auxiliary battery and installed a 2,000 Watt Inverter into the towing vehicle. I am still approx. 50 watts short of ideal Solar Watts to Battery Amps ratio of 2 to 1.
FollowupID: 927165
Reply By: Anthony T8 - Monday, Sep 23, 2024 at 14:38
Hi Macca
Could never be offended about battery talk.
My point was trying to suggest to KathyW2 that a big expensive trip like the one they are planning is really about the experiences- they last a lifetime.
Setting-up to be free of concerns about cooking, heating, running-out etc just made the daughter's family trip so enjoyable. It's not hard with the gear available now.
Cheers.
AnswerID: 646544
