Tips for attaching an awning with gull wing aluminium canopy
Submitted: Friday, Mar 14, 2025 at 15:15
ThreadID: 149900
FollowUps:5
Member - Keith B (QLD)
How do I attach an awning with an aluminium canopy. The awning was previously attached to a troop carrier roof rack.
Problem is that canopy has to rise then fall to get over open gull wing when that door is opened.
Reply By: Bob Y. - Qld - Friday, Mar 14, 2025 at 20:30
I’ve got an awning on each side, Keith, and mounted the brackets to the roof. Need some good sealant when mounting the brackets.
IF I remember tomorrow, I’ll take a couple of photos so you can see if it will suit your canopy.
Mounting Brackets-Darche Awning
Only one bolt needed through the roof, as outer bolt mounts into a keyway in the outer extrusion.
Bob.
647589
Reply By: Batt's - Saturday, Mar 15, 2025 at 00:49
Should be able to buy brackets to suit which means drilling into the canopy roof and making the holes waterproof.
My canopy has the aluminium ladder racks welded to the roof which was an option when I bought it 10yrs ago and are very handy. I attached the awning to that, it's handy for carrying timber etc from the hardware store for example and they sit higher than my fixed solar panels so keeps any loads off them. If I didn't have the ladder racks I would have to muck around using the box trailer more. Plus if you want another awning on the other side it's an easy fit or tie on a rope for a clothes line to a tree they are solid and have many uses.
647590
