Improved Route Planning Tools for Traveller
Submitted: Tuesday, Jun 16, 2026 at 10:02
ThreadID: 152747 Views:445 Replies:2 FollowUps:2
Hi ExplorOz team,
I’m wondering whether more direct click-routing options are available in Traveller, or whether this is something that could be added in the future.
What I’m looking for is the ability to click points on the map to build a route, have the route follow roads/tracks between those points, and then export the finished route as a GPX file.
At the moment, the process of clicking on places, adding them to a route, and inserting custom waypoints to force the route along the roads or tracks I actually want to take feels clunky. For me, this is probably the current limitation of the software.
The frustrating part is that the ExplorOz maps are excellent, and in many areas they are much better than the alternatives. However, other mapping apps seem to handle route creation and GPX export much more smoothly. Their maps just aren’t as good, especially for remote or off-road travel.
Is improved click-to-route functionality something that is currently available, planned, or being considered?
I think being able to quickly click through a route, adjust it on the map, and export a clean GPX would make Traveller a much stronger tool for trip planning, particularly for motorcycle, 4WD and remote touring users.
Thanks.
Back Reply Expand Un-Read 2 Moderator
Reply By: Member - Duncan2H - Tuesday, Jun 16, 2026 at 11:26
I appreciate its not 100% what you're after, but the "measure tool" allows you to "click out a line" and then convert that into a Track Log.. just the line though, no interpretation of roads that match your line.
Draw the line then hit the little Save icon that appears to create a Track Log
This is what I use, I then add the Track Logs to a Folder. Each major trip has its own Folder that consists of Places and small Track Logs that I've created with the Measure tool.. I really don't use the inbuilt automatic Navigation tools within ExplorOz - road selection between two points is always my own decision.
AnswerID: 649316
Follow Up By: Member - Happy Explorer - Tuesday, Jun 16, 2026 at 16:41
Hi Duncan
In support of what you have said, I too use the measure tool. It is rather primitive but quick and easy. I gave up on the route tool a long time ago as it was hopelessly slow and complex to use. Need to be able to select start and end points then if not where you want to go just drag and drop the route to the places and roads/tracks that you want to include. Would be so user friendly to use and easy to adjust mid trip if required. I have seen something very similar on another app somewhere but probably outside the capability of the software David is using. Don’t know.
Roy G.
FollowupID: 931101
Follow Up By: Member - Callum P - Monday, Jun 22, 2026 at 09:33
Hi Duncan,
Although I'm sure this isn't quiet how the creator intended this measure feature to be used, it's actually quite effective. It allows me to create a series of "waypoints" using the measure tool and export to a GPX which can be converted to a route in Garmin Tread and allow use on my Garmin Zumo XT2, allowing for quick route creation.
Thanks very much for the suggestion. With some small refining this tool would actually be much more useful than the route creator within Explor Oz.
FollowupID: 931128
Reply By: Member - ValueRider - Sunday, Jun 21, 2026 at 06:11
That feature would be great!
AnswerID: 649328
